Can an LS1 powersteering pump take atf?
Old Jul 31, 2008 | 03:04 PM
monger's Avatar
Default Can an LS1 powersteering pump take atf?
doing a swap where the factory rack in the car uses atf, is it ok to use atf in the LS1 pump?
Old Aug 1, 2008 | 08:34 AM
cnichols's Avatar
I believe I did, but it's been over a year since I filled it up.
Old Aug 1, 2008 | 09:22 AM
jannes_z-28's Avatar
ATF will be foamy. ATF can't handle the heat a power steering system can generate.
That's why there is Power Steering Fluid. Use that!
Jan
Old Aug 1, 2008 | 09:29 AM
monger's Avatar
Jan
the car that the LS1 is going in has a steering rack that specifically calls for ATF, not power steering fluid. I am leaning towards using atf because it will be more expensive to change the rack than to replace the pump.
Old Aug 1, 2008 | 09:39 AM
LS1GMCTruck's Avatar
Very common to use ATF Dextron lll in steering systems of all kinds. The LS1 pump uses it. Everyone that puts a LS1 in another vehicle uses it. A GM transmission, for which Dextron ll & lll was designed, is in the same operating temperature range as your power-steering system, with regards to fluid.
Old Aug 1, 2008 | 09:52 AM
04600rr's Avatar
like you said before the pump is a lot easier to replace then the rack.......I would use ATF..
Old Aug 1, 2008 | 10:01 AM
monger's Avatar
Thanks for the clarification, just what I wanted to hear
