towl/haul quite working
Old Aug 4, 2008 | 09:22 AM
rockytopper's Avatar
Default towl/haul quite working
What are the most common problems that causes this to quite working? This is a 2002 Z71 truck with just under 100k miles.
Old Aug 4, 2008 | 09:38 AM
Eric Anderson's Avatar
In my '02 Tahoe I have to put slight upward pressure on the column shifiter then hit the button. The button is end of the column shifter. Its like the shifter is slightly out of position or something. Try moving the shifter toward the park position, but not moving out of overdirve, while hitting the button.
Old Aug 4, 2008 | 09:57 AM
TRANSAM75's Avatar
I sell 3-4 shift lever w/switch's a week at a G.M. dealer. Just poor design.
Old Aug 12, 2008 | 09:23 AM
So basically it is most likely a switch issue? I'll give the move the stick trick a try.
Thanks for the help guys
