Can a 98 PCM work with different year 4L60e ?
Old Sep 1, 2003 | 08:03 PM
99 Black Bird T/A's Avatar
Default Can a 98 PCM work with different year 4L60e ?
Can a 98 PCM work with different year 4L60e?
Will the 98 PCM work with a 4L60e out of a 98+ pick up truck that had a Gen III engine?
If so which years can you mix and match to the 98 PCM?
Thanks
Old Sep 1, 2003 | 08:09 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: Can a 98 PCM work with different year 4L60e ?
Yeah, the 98 PCM will run any of the 4L60E trannys ok.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Sep 1, 2003 | 09:49 PM
88SS LS1's Avatar
The trans does not matter as much as the wiring harness's must match.
Old Sep 1, 2003 | 09:59 PM
harness's?
Is their a wiring harness for the tranny as well?
Old Sep 2, 2003 | 08:43 AM
onehardmaro's Avatar
Engine harness and console harness are the main ones
Old Sep 2, 2003 | 12:12 PM
88SS LS1's Avatar
Just make sure if you have a 98 PCM you have a 98 wire harness or you will have to rewire the harness or get a new harness due to the different pin outs between 98 and 99 harness's
