Wirng question
Old Aug 24, 2008 | 07:52 PM
trentonz28's Avatar
Default Wirng question
I've started to modify the harness from my 2004 GTO engine for my first gen camaro and I need something cleared up. I found that several wires are designated as "ignition" 1, 2, or 3. I assume these are ignition on, start, or accessories, but I need to know which is which. I appreciate any help, thanks
Old Aug 24, 2008 | 11:33 PM
G-Body's Avatar
sawzall wielding director
Most likely those wires are all pink? and they need to be hot in run and start. I don`t have diagrams for an 04 GTO, but this is common on many of the other LSx harnesses. They have more than 1 wire that has +12v in the start and run positions. The are usually fused separately so they are labeled IGN 0, IGN 1, IGN 2, etc.
Old Aug 25, 2008 | 11:31 AM
fmowry's Avatar
'04 GTO pinouts.
https://ls1tech.com/forums/showpost....81&postcount=1
I'm using an '04 GTO harness for my Miata conversion. I'm trying to strip out unused stuff and convert from A4 to M6 while I'm at it. I haven't gotten that far yet but have labeled all the GM wiring I'll need to jump to the Miata stuff.
Frank
