Which aftermarket A/C for 69 Camaro
Old Aug 26, 2008 | 02:40 PM
Tommy69z's Avatar
Default Which aftermarket A/C for 69 Camaro
I searched. and have read till my head in spinning. I want to use the factory compressor, mainly for cost savings, but some say it will work, vintage says it won't. Who has used the factory LS1 compressor with what kit? I found a good deal on VA, and on HRA, so which one?
Old Aug 26, 2008 | 05:49 PM
SUPERBOOST's Avatar
Check out classic auto air in Fla.,I think its a lot better system than vintige.I can't give you a defenite answer on the factory compresser but I think a few folks have gotten it to work.
Old Aug 26, 2008 | 06:39 PM
dhutton's Avatar
Everything I have read seems to indicate that the Gen 4 system from VA has the best cooling capacity. The same unit is used in the Ford GT which is what is was originally designed for.
Give Frank at Prodigy Customs a call to discuss the use of the stock compressor. He's taken a lot of product training and has installed quite a few of these systems from all manufacturers. Not too many sellers can give you the pros and cons of all of them from first hand experience.
Don
Old Aug 27, 2008 | 02:36 PM
mjls1's Avatar
Active Streak: 30 Days
I have got a classic auto air and works great. I checked with vintage air when I was shopping for after market a/c and they wanted to sell me there compressor and brackets. Classic auto air was great to work with. I told them what I was doing (ls1 with 4th gen compressor into my 71 camaro) and they sold me a kit minus the compressor and brackets. They also welded correct new barbs onto the aluminum lines for the 4th gen compressor with the hoses crimped on.
