fox swap radiator?
Old Sep 3, 2008 | 12:39 PM
allblacksrt4's Avatar
Default fox swap radiator?
you should be able to use a stock fox radiator with a electric fan right?
Old Sep 3, 2008 | 02:03 PM
Crowder's Avatar
everyone says f body works fine, im using a c5 radiator my buddy had.
Old Sep 3, 2008 | 03:27 PM
97'-lt1's Avatar
I'm using the f-body fan and radiator setup..fits great, only modification is cutting an alignment tab off the bottom of the radiator...
Old Sep 3, 2008 | 03:47 PM
but is the any reason you cant use a fox radiator and a electric fan kit? i am trying to make this the most low budget swap ever lmao.
cause i am going to carb so there will be no f body wiring.
Old Sep 3, 2008 | 09:55 PM
936LNOTCH's Avatar
I'm using the f-body radiator and fans. Radiator was 110 new and fans i found on car-part.com for 40 plus shipping.. The fans are awesome!
