LSX Fox body swap...
General concensus I've read is : AJE k-member,kooks headers, fabbed trans mount(?) 6speed or auto.
some of my questions are - what ECM and Harnesses is everyone using(stand alone,FAST engine management,BS3?), 6 speed guys what are you using for clutch slave cylinder etc, is there any issues with brake booster, power steering etc.
Is the swap any easier using an F-body motor vs. truck motor (TBSS)
Thanks in advance, and yes I just started my research and I have several threads bookmarked and I thank you!!
As for motor to use.... It really does not matter. What does matter is what front accessories you choose to use. Again the most common and easiest to use IMHO is the Fbody front accessories. The truck stuff works as well but not as clean or easy without a little bit of tweaking.
No issues with the brake booster. You can even upgrade to the Cobra/SN95 booster which is larger and still have room.
For power steering you will use the GM pump and brackets and need to have both the pressure line from the GM pump as well as the original pressure line from the Ford rack up to the pump - with these you can take them to a hydraulic shop and have them make you a custom line. The low pressure line is a real no brainer..... it is just rubber hose that goes from the pump to low pressure side of the rack. If going manual steering then I would look into which fits your budget best. The Flaming River is great quality IMO and is available anywhere really. For my car I used a UPR Kmember and the factory power rack, I had to lengthen the factory steering shaft a bit since the modular Kmember moved the rack location forward. I think I added about one inch..... A custome shaft would also be a very easy fix.
Hope this helps. Good luck with the build.
Dave
