a il hepl is all i need
Old Sep 8, 2008 | 01:46 PM
burntrack's Avatar
Default a il hepl is all i need
i have a coil harness and wanted to know is they are switchable from driver side to passenger side. also looking to buy oil dip stick, coil bracked bolts to hold to valve covers and one valve cover hold down bolt. ready to get my 69 5.3 ls1 powered impala on the road........
Old Sep 9, 2008 | 07:31 AM
oange ss's Avatar
1. coils and harness' are not side specific
2. coil bracket bolts are 6mm x 1.00mm x 25mm ( i think, double check lenght), go to any hardware store and grab some
3. will probably have to go thru GM for the valve cover bolt
Old Sep 9, 2008 | 09:38 AM
LS1MCSS's Avatar
The harness might swap from side to side, but then the wire colors won't match the schematics and might cause problems later on, if you need to trouble shoot.
