Relocated battery, what size of cable?
Old Oct 2, 2008 | 10:35 PM
a10beav's Avatar
Originally Posted by 1999ls1snake
It's much better to use a solenoid. This way the cable is only live when cranking. Put the fuse on the alternator cable instead. Littlefuse makes nice Mega fuses in the 80 to 200 amp range. 100 amp should be plenty.
Is the solenoid back by the battery? So an ignition wire needs to be run back to the solenoid?
Old Oct 2, 2008 | 11:16 PM
1999ls1snake's Avatar
Yes. Just splice into the existing ignition wire. Put a 10A in-line fuse on it and run it to the back. The solenoid has the added advantage of being used as a power center if you need connections for large amps in the trunk. A Ford solenoid for $15 will do the trick.
Old Oct 3, 2008 | 01:23 AM
HELLBENTfabrication's Avatar
i actually cant believe some of the things im reading here!!!
this is the best i could do for finding a chart for sizing battery cable......this does not just apply to marine applications
http://www.e-marine-inc.com/products...rs/cables.html
0 or 1/0 battery or welding wire is would be a good start. try to get a fine strand cable.
use the same size ground or larger
unibody cars should get grounds from battery to body, body to engine
framed cars should get grounds from battery to frame AND body, frame to engine
Old Oct 4, 2008 | 04:04 AM
Jeff Smith's Avatar
I got good information of Powermaster>>
How choose to alt. rate???
http://www.powermastermotorsports.co...ternator_.html
How I choose wires for charge?
http://www.powermastermotorsports.com/charge_wires.html
