VSS without a 4L60E
Old Oct 1, 2008 | 12:39 PM
cacmanjr's Avatar
Default VSS without a 4L60E
I am using a 200-4R. Anybody know if there is a sender that will connect to the speedometer cable fitting on the trans to get VSS for the computer?
Old Oct 1, 2008 | 12:45 PM
Jones'n's Avatar
The website isn't the greatest, but these guys have all kinds of useful stuff...
http://www.transmissioncenter.net/4L60E.htm
Old Oct 1, 2008 | 12:56 PM
LS1MCSS's Avatar
Jagsthatrun also sells one.
Old Oct 1, 2008 | 04:43 PM
bczee's Avatar
Cable-X is also another good product that will work.
Old Oct 1, 2008 | 08:26 PM
poconojoe's Avatar
They came on some of the stock GM's I know the 1988 P series vans used one, even certian Fbodies used them
Old Oct 1, 2008 | 08:32 PM
cacmanjr's Avatar
Thanks to you all for the information. I didn't know where to look and google searches were no help. The one with the correct output from Jagsthatrun is designed to bolt to the yoke on a S10 rear end and I run a 12 bolt. They did not answer my email inquiry so I gave up on them. I will look at the sites you guys directed me to. Thanks again!
Edit: Looked at Cable-X and PATC sites and no luck yet. Any other sites out there?
Old Oct 2, 2008 | 11:10 AM
LS1MCSS's Avatar
Get the 4 pulse from jagsthatrun and program the pcm to match it. The have one that's a pass through design so you can run the cable speedo if that's what you need to do. I think their p/n is 4PAC, or something like that.
Old Oct 2, 2008 | 12:49 PM
cacmanjr's Avatar
Thanks LS1MCSS. I did not know that the computer could be programmed to accept a different signal. That makes it a lot easier.
Old Oct 2, 2008 | 03:01 PM
LS1MCSS's Avatar
Just make sure you order a two wire sender. They put out the correct type of signal. You will have to re-program for the number of pulses, though.
Old Oct 2, 2008 | 06:05 PM
cacmanjr's Avatar
Will do......and thanks again!
