1952 Fiat Topolino
Old Apr 11, 2026 | 05:41 PM
Scott Danforth's Avatar
Was at cars and coffee today.....1992 Mazda Autozam AZ-1
64hp and slightly smaller than a kitchen table
Old Apr 26, 2026 | 04:33 PM
Making chips on the 799 heads.
Old Apr 27, 2026 | 08:41 PM
gjestico's Avatar
Interesting build ! . So that dodge bellhousing bolts up to the LS block as is ?
Old Apr 29, 2026 | 04:25 AM
The LS4 uses the GM 60 degree bellhousing pattern
The Jeep and dodge 2.5 liter 4-cylinder also uses the GM 60 degree bellhousing pattern.
I have about 4 or 5 bellhousings for T5s and Saginaws that would also work. But I want to run the AR5.
So since Jeep and Dodge use the Aisin AX-15 which is the sister transmission to the AR5 and the Toyota R154, the Dodge Dakota 2.5 liter bellhousing allows the motor and transmission to be bolted together without adapters
The original starter pocket location is where I will be locating the starter with a custom mounting plate
The Jeep bellhousing is also large enough to run a 153 tooth flywheel vs the normal LS4 142 tooth. jeep/dodge uses a 148 tooth flywheel like GM did on the RWD 60 degree engines
Old Apr 29, 2026 | 04:28 AM
Old Apr 29, 2026 | 06:40 AM
Now onto the starter mount. since the LS4 has a raised portion for the 60 degree pattern off the standard Chev pattern, there will now be a gap between the lower ears of the bellhousing and the back of the oil pan.
perfect location for a laser cut sandwich plate that will act as a block scatter shield, a spacer, and most importantly, a surface to bolt a ford style starter.
since the aftermarket mini starters for ford, GM, etc all have the same motor and gear head, and only differ from the mounting flange.....enter in a SBC starter without the mounting flange . now I just need to make a mini version of the ford mounting flange to mount it to the piece of 4mm steel plate.
Old May 4, 2026 | 11:20 AM
Water manifold came in
Need to dress the gasket surface and tap the sender threads
Old May 5, 2026 | 05:16 AM
LS1-IROC's Avatar
Is that manifold 3D printed?
Old May 5, 2026 | 06:13 AM
yes, went the fabrication route first using a stack of 1/8" and 5/8" laser cut plates. went this route after a leak was discovered 2 layers deep that could not be repaired
Old May 6, 2026 | 05:12 AM
LS1-IROC's Avatar
Nice, looks like they did a nice job, was that done stateside or China? Care to share who you used? I'm looking to have some things printed out of aluminum soon.
Old May 6, 2026 | 08:28 AM
Pocket's Avatar
Nice!
3D printing seemed like a better fit for something so complex
Old May 6, 2026 | 03:09 PM
i went thru a global supplier we use at work. I believe this was Ninghai China.
Old May 8, 2026 | 12:26 PM
With the correct hardware and nipping the corner of the cam sensor retaining tab. It fits
Now to finish the porting of the heads and get the custom flywheel and starter mount made
