power antenna question
Thanks!
There was one main difference... the mast housing and how it mounts to the sheet metal was completely different. Our factory '99 'vert one had a rubber grommet that fit in the sheet metal and then the mast of the antenna just fit snug into it. The one out of the '98 apparently has a bezel that fit on the sheet metal and/or threaded onto the mast housing. Luckily (after some cussing) I discovered that you could remove 2 screws and remove the top mast housing (pot metal or aluminum piece) and I just swapped those out... then it all bolted in and worked perfect!
