Convertible Vehicles Enthusiasts | Information | Maintenance
Monsoon HU replacement in verts
Old Jan 19, 2009 | 05:35 PM
xny1989's Avatar
Question Monsoon HU replacement in verts
I've run into some frustrating problems replacing my monsoon HU.
http://images.ibsrv.net/ibsrv/res/sr...r_banghead.gif
Bottom line is when it was installed, and working properly, including shutting off when the ignition was off, it drained my battery. I've posted this in the stereo section, but have gotten little response. I did a search and found one member here that had the same problem, and in a vert. I was wondering if anyone else here had similar problems. All the details of this are in the stereo section, under the title "HU install draining battery"
https://ls1tech.com/forums/stereo-el...ery-drain.html
Thanks
Last edited by xny1989; Jan 20, 2009 at 12:36 PM. Reason: added link to the message
Old Jan 20, 2009 | 08:23 AM
Ragtop 99's Avatar
All the details of this are in the stereo section, under the title "HUD install draining battery"
I haven't had this issue, but to many people, HUD = Heads up Display, something not on an F-body. If it is the monsoon head unit that is causing your problem, you might edit your post title in hopes of getting more looks.
Old Jan 20, 2009 | 12:35 PM
xny1989's Avatar
Ragtop,
thanks for the "heads up" on my mispelling LOL
Old Jan 20, 2009 | 12:52 PM
SOMcockySS's Avatar
If you need another Monsoon HU, I got one from a 20k mile car that I can sell you pretty cheap. Let me know.
Old Jan 20, 2009 | 02:46 PM
xny1989's Avatar
thanks SOM, but I'm staying with the replacement. The monsoon that I removed has all the light bulbs blown. I've reinstalled the replacement, and will see what happens overnight.
