Convertible Vehicles Enthusiasts | Information | Maintenance
Top issue
Old May 22, 2009 | 12:29 PM
t/afrom504's Avatar
Default Top issue
Ok my top goes down but not up. I checked my fluid and its really low. I know its common sense but just be sure, do I need to fill it back up with fluid in order for it to work?
Old May 22, 2009 | 01:17 PM
GR8RYD's Avatar
That's where I would start. I think there is a sticky about doing it.
Old May 23, 2009 | 06:32 PM
t/afrom504's Avatar
I cant seem to find a quart of this fluid...only 5 gallons of it. I searched and found that brake fluid or ATF would work, is this true?
Old May 26, 2009 | 08:49 AM
Bajapat's Avatar
I got mine a pep boys
Old May 27, 2009 | 10:26 AM
t/afrom504's Avatar
Well I filled it back up now it only goes up and down sometimes and barely that. Im beginning to think that the motor is out. I tried banging on it, then it would go halfway up then stop...whats next???
Old Jun 2, 2009 | 09:21 AM
LS1Z28's Avatar
Sure that will work if you want to replace the pump and rams. GM sent out a TSB to the dealers back in 1999 USE only Mineral oil.You can find it at any drug store or supermarket.
Old Jun 18, 2009 | 02:18 AM
alasad's Avatar
Default Mineral Oil
I followed advice on other posts and used mineral oil bought at a drug store. Inexpensive and easy to fill. There is a resovoir adjacent to the vert motor. Used it last year and the motor works good. Tip; whenver I decided to take the top down, I unlatch it and give the top a starting push. I think this may prolong the vert motor. Hope this helps.
Old Jun 18, 2009 | 03:12 AM
BigT2002's Avatar
get it fixed??
Old Jun 21, 2009 | 12:32 PM
t/afrom504's Avatar
not yet...havent had any time but I may do it today
Old Jun 26, 2009 | 06:18 PM
t/afrom504's Avatar
WELL i finally found the problem...it didnt want to go back up only because I put it to far down. But when going back up it moves SLLLOWWW....maybe the mineral oil will speed it up some I hope...I'll see
Old Jun 28, 2009 | 12:51 PM
proporio's Avatar
Bang on it harder--use a bigger hammer
motor might be going bad
