anyone know how to remove the pump?
If you get voltage, use the DMM and measure the OHMS across the motor terminals. If you get anything > 100 ohms, your motor is probably cooked.
The plate holding the motor unbolts in 2 or 3 locations and lifts out. Be careful of the hydraulic hoses. You might want to lable those and remove the 4 going to the cylinders. Use a container to catch the fluid, it'll make a mess pulling the motor / pump assembly out. Not sure if you can order just the motor or the entire motor / pump / resevoir assembly.
Good luck.
