Convertible Vehicles Enthusiasts | Information | Maintenance
Leak
Old Jan 5, 2010 | 02:12 AM
c-dub's Avatar
Default Leak
I've recently discovered that my trunk has a few inches of water in the bottom of it and it's leaking through that into the backseat floor and causing it to be wet. has anybody else experienced that problem!? lol it's a total FML issue.
Old Jan 5, 2010 | 06:25 PM
LS1Wonder's Avatar
Yes, I have had the same issue when i first purchased mine. It's the drain holes in the rear fender wells. Lower the top all the way down and look between the top and frorward-most section of the rear quarter panels, you'll see the drain holes, and most likely they're filled with crap like leaves. When they clog, water diverts into the rear passenger floorboards. Clean em' out and vacuum the carpet and enjoy your leak-free vert!
