Convertible Vehicles Enthusiasts | Information | Maintenance
Roof replace
Old Apr 21, 2010 | 08:53 PM
YORK_MUSTAINE's Avatar
Default Roof replace
some body have seen a instructions or how to,, for a replace a roof in a convertible camaro ss?
i got a new roof and its not so easy replace, im trying 2 days
Old Apr 24, 2010 | 10:42 AM
Stuinkuwait's Avatar
I have seen a top supplier on ebay that has a DVD install video 4 sale. I was going to get it just to see how hard it is to replace.
Old Apr 26, 2010 | 11:36 AM
THANKS SO MUCH
I FOUND IT
http://cgi.ebay.com/ebaymotors/Camar...Q5fAccessories
Old May 2, 2010 | 07:44 PM
NBM2002WS6Vert's Avatar
I bought that DVD a while back just out of curiousity. Seems to provide very clear instructions and a lot of little tips that you wouldn't know just from poking around.
Good luck!
Old May 2, 2010 | 09:18 PM
reelnauti's Avatar
Thumbs down
The first thing you have to do is check the rear bow height and adjust the top pad as necessary. I am assuming you are doing the glass and the top also. then put the rear glass in according to the bow height work from the middle out. It is very difficult to get a top on to look good no wrinkles or bagginess. also make sure the glass is not to high or low for the top part it has to cover the top of the glass should be an overlap. After you are satisfied with rear glass. Start on the top at the rear bow again. center the top on the rear glass with the overlap. attach at the bow. work top now to the front. usually there are marks from the top manufacturer where the front should line up all the way up front. do the rear section from the bow to over where you attached the rear glass. I have done multiple tops and all are different. each top has it's own problems. Good Luck
