Top's control button/switch replacement.
It was in two pieces and inside prongs were showing.
If it's fried, I'm not sure at the moment since I didn't have time to check fuses.
Can I buy a generic switch from radioshack and solder it lin like people use for E-cutouts or would I have to get a GM replacement?
I also need the tech specs for the switch I 'd need.
Thanks in advance.
This specialized switch reverses polarity to the motor in order to switch from "up" to "down". See attached diagram.
Best to get an OEM replacement. Wish I had the PN for you.
eseibel67, JohnnyBs98WS6Rag thank you both for your input. I picked up an oem switch from a local dealer.
Now If I could only find the Twin Switch bezel for the cutout.
