Convertible Vehicles Enthusiasts | Information | Maintenance
Tips on Replacing carpet ??
Old Mar 22, 2015 | 10:24 AM
bad_408_vert's Avatar
Default Tips on Replacing carpet ??
So I have kicked around the idea of replacing my car's dirty old tan carpet.
I have a ebony carpet from T-TOP car, will this work?
Whats needed to remove the rear plastic panels by the seats?
Any other information of anything tricky I may run into is appreciated?
Thanks!
Old Mar 30, 2015 | 04:06 AM
fbodyrs96's Avatar
I used one form a coupe also, it fits.But needs to be trimmed on the sides because it is wider, also it's a pain in the butt to get up and over the seat belt brackets in the rear (which the carpet will have to be cut to go over them) and finally the carpet will c be a few inches short in the trunk.
Old Mar 30, 2015 | 01:24 PM
Atrus_SS's Avatar
Interesting! Never knew that. I always assumed that the convertible floor pan would be slightly different for bracing or something, and the coupe wouldn't fit.
Old Mar 30, 2015 | 03:54 PM
chaney1974's Avatar
same carpet remove all panels for easier installation and take your time results will be much better
Old Apr 4, 2015 | 09:37 AM
Fbody96RS - you are the man!!!
This is exactly Info I was looking for.
About where does the carpet fall short on the gas tank?
Did you sew another piece of carpet on or just laid a square mat down that slp makes?
Did your replacement carpet come with the jute matting or did you swap from original carpet?
Old Apr 5, 2015 | 07:29 AM
fbodyrs96's Avatar
Stock oem 96 coupe carpet and backing'
No, I didn't add any carpet
It's about 3-4" form touching the trunk carpet piece I guess, I have some black spray in sound deadener lining my trunk so it's really not that noticeable anymore and I use my boot bag to cover it when at shows.
