Convertible Vehicles Enthusiasts | Information | Maintenance
Water run off??? Adjusting top?
Old Oct 30, 2005 | 04:20 PM
93TAWicked1's Avatar
Default Water run off??? Adjusting top?
I just put a used 15K mile top on my vert. Lotsa work but not hard, My question is that it does leak a little bit on the rear bow, but there seems to be a water runoff there on purpose. Is this supposed to be a water tight seal. The front and side windows seem good although I thing the top needs a little adjustment. I might just take it to a body shop and have them adjust it.
Anyone want a dirty tan top that doesn't leak
Old Oct 31, 2005 | 05:21 AM
Dustin's Avatar
Its not supposed to be watertight. The runoff catches all that water and dumps it under the car. The runoff works great so you dont need to adjust anything.
Old Oct 31, 2005 | 12:07 PM
Thanks for that, It pretty much looked that way but seeing little streams of water running into the interior was pretty scary. It seems to seal OK then the only problem is it seems a little croked in front the drivers side latch goes all the way down while the passengers is out a little bit with tension. I assume that there is a way to adjust it but it seems like you'e have to loosen everything again to do it...I might have a shop do that.
How tight do you tighten the 30 bolts in the back bow? I went pretty tight with it because alot of water was coming in at first. Tightening it up lessened the amount considerable.
Thanks for all the help man!!!
Old Oct 31, 2005 | 05:37 PM
Dustin's Avatar
Just hand tight i would say, dont torque the **** out of them because the body will strip pretty easy and then you have to use bigger bolts as I am doing on Nine Ball's 69 camaro right now, some ******* stripped almost every bolt out by torquing it too hard.
