Convertible Vehicles Enthusiasts | Information | Maintenance
Top Sagging
Old Nov 13, 2005 | 11:24 AM
ssmoov1's Avatar
Default Top Sagging
My top has just started sagging really bad in the last year,its not a DD so it justs in the garage and goes to the track.Is there any way to
tighten these tops up? I've searched but could not find out anything.
Joe
2001 SS Convertible
Old Nov 13, 2005 | 06:47 PM
Dustin's Avatar
Tools: Phillips head screw driver, contact cement, something to punch holes in the material.
First, turn off te hydrualic valve in the trunk. Next lay the top all the way back till it is down. Take a marker and mark a few spots along the edge of the top. Next unscrew the header panel. This will expose the material that is glued down. Pull it up, your top should move freely now. Depending on how stretched out it is, pull the material about 1/4 - 1/2 of an inch, i normally do half. Punch new screw holes in the material starting from the center and working your way out. Screw it down the close the top and make sure it is a little tight yet no creases. Now you can lower it back down, unscrew the screws. Next you want to glue it back down, the best thing to use and i use it on all tops it Dap Contact Cement from Lowes, about 3-4 dollars a bottle. Spread that on where the old glue was, lay the material back down, screw the header panel on. You are finished! This sounds like alot but it will literally take you no more than 30 mins tops. Dont forget to turn the valve back on.
Old Nov 16, 2005 | 07:02 AM
cablebandit's Avatar
i did EXACTLY like you said and my top looks MUCH better. It doesnt sag anything like before. Thanks!!!!!!!!
Old Nov 16, 2005 | 08:18 AM
ssmoov1's Avatar
Thanks alot buddy I'll give it a try after I get my motor back together.
Joe
2001 SS Convertible
Old Nov 16, 2005 | 09:44 AM
Dustin's Avatar
Glad I could help!
