Convertible Vehicles Enthusiasts | Information | Maintenance
BMR subframe connector help
Old May 6, 2006 | 11:15 AM
Josh2006's Avatar
Question BMR subframe connector help
well i am about to install my bmr sfc and my dad was woried about when he will weld them to the flore pan about it heatin up the carpet on the inside of the car and possible catching fire
anybody i need your advice pull up the carpet or are we woried about nothing
-Josh
Old May 6, 2006 | 03:07 PM
XLR8TOR's Avatar
Shop that did mine didn't pull the carpet... and it ain't burnt
Old May 6, 2006 | 03:18 PM
Honda Hunter's Avatar
same here.
Old May 7, 2006 | 07:24 AM
GR8RYD's Avatar
Not sure what kind of welding your dad was planning on using, but I have been told to stay away from tig welding and whatever you do, be sure to remove both battery cables to keep from frying the car's computer. Now, these may just be old wives tales (nothing against old wives) but I thought I would mention them. Hopefully someone with more accurate information/experience will speak up. Mine were professionally mig welded and they did not have to do anything to the carpet.
Old May 8, 2006 | 08:18 AM
BMR Suspension's Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You should have them mig welded and you will have no problems. You do not need to pull the carpet just pay attention when you are installing them and you should be fine.
Lee Spicher
lee@bmrfabrication.com
(813)986-9302
Old Oct 27, 2006 | 10:02 AM
AngryJ's Avatar
bump for the deadly. As far as mig welding is concerned, how much current is required to heat the subframe? Would a 110amp 120v mig be sufficient?
