Convertible Vehicles Enthusiasts | Information | Maintenance
Top troubles >:(
Old Jul 2, 2006 | 03:05 PM
Shamson5.7's Avatar
Default Top troubles >:(
So today getting to the gym I go to put the top up and I hear a slight grind and then a loud pop and the top suddenly fell to about a 45% sideways leaning down towards the drivers side. I adjusted it to at least get it closed so I could work out and fix it later.
Anyhow I get it home and it wont go down unless I guided it. Turns out the bolt that held the hinges(thats the best I can describe it as) had unscrewed and popped loose AND fell ALL the way to the bottom kidna where the quarter panel is.
Took me a good 30-40 minutes to extract the damned bolt do to having my fatass fingers.
Anyhow as I finally get the bolt I had to take off the plastic piece that surrounds the ugliness. As I FINALLY get to the bolt about an hour or so into this project I realize that after about 20 turns or so that it thing is stripped...not the bolt the hole that it goes it .
My quick thinking led me to a roll of "plumbers tape". I wrapped the end of the bolt with it nice and tightly and it screwed in just fine. I gave it a couple of hefty jerks to make sure it wasnt going to go anywhere and presto...fixed that pos.
I have no clue why the bolt just decided to pop out all of a sudden...the top goes up and down about twice a day every day for the last 2 months or so and Ive NEVER had ANY kinds of noise or problems until out of the blue today.
Anyhow I thought I would share my adventure.
Old Jul 4, 2006 | 08:24 AM
96transamconvt's Avatar
I too had the same problem, the damn plastic end that the bolt was retained with let go. So I used a larger bolt with lock tight. It's held now for a year
Old Jul 6, 2006 | 12:36 PM
tracetrimble's Avatar
https://ls1tech.com/forums/convertible-vehicles/492421-stripped-threads-top-mechanism.html
was yours the same bolt? (other side, of course)
Old Jul 26, 2006 | 05:08 PM
Shamson5.7's Avatar
Yes it was the SAME EXACT bolt.
