Convertible Vehicles Enthusiasts | Information | Maintenance
TH350 In Vert ?'s
Old Dec 6, 2006 | 08:20 AM
ssmoov1's Avatar
Default TH350 In Vert ?'s
I will be installing a Rossler TH350 this weekend and was wanting to find out if I have to run the vert crossbrace from SLP which is in the car now or just take it out,because it wont bolt up to the BMR TH350 tranny crossmember.If I do take it out will I have to get a tunnel brace? Just dont know how critical these crossbraces are in a vert and dont want the floor or tunnel area buckeling on a hard launch with the t-brake and 200 shot.Any help will be appreciated.
Joe
Old Dec 6, 2006 | 07:35 PM
Ragtop 99's Avatar
Does the SLP brace replace the flimsy stock x brace? If yes, you can run without under normal circumstances. You might a little bracing back with a drive shaft loop.
BTW, I don't consider a T-brake & 200 shot normal. If you are looking to be 1.3 - 1.4 in the 60', I'd invest in some serious bracing unless you have a cage that goes through the floor and is welded in the subframe.
