Convertible Vehicles Enthusiasts | Information | Maintenance
Lowering Springs
Old Jun 18, 2007 | 12:01 PM
Frechles71's Avatar
Default Lowering Springs
Hey ive been looking at some drop springs and a few i found say that they will work for all 4th gens execpt covertibles... what is the difference between the verts springs and non-vert springs?
Old Jun 18, 2007 | 03:01 PM
FastrDamnit!'s Avatar
verts weigh about 140lbs more than coupes, most of which rests towards the rear of the car.
Typically aftermarket lowering springs will sag/bottom out in the rear unless specified for verts.
If you want to lower can can't find springs just keep stock springs in back and remove the rear isolator rubber spring perch (lowers rear about 2/3 inch) and get a set of 1" lowering springs for the front.
Old Jun 19, 2007 | 07:11 AM
Frechles71's Avatar
ok thanks... that makes a lot of sense... so who makes lowering kits specially for the drop tops?
Old Jun 19, 2007 | 03:11 PM
900hpSS's Avatar
GMMG makes a nice set of springs that look good on the convetibles, but good luck finding some.
