Leak!
What can I do to determine the cause of the leak and what kind of shop can I bring it to to have it fixed? Or is there something I can get from AutoZone that I can do myself?
I've read that the seals are supposed to be treated with silicone grease to keep them soft. Wondering if that might help. Does Autozone carry "silicone grease"? Not sure exactly what I am looking for, maybe Permatex makes something? Don't know.
- M i K e
This is what you're supposed to be using:
GM WEATHERSTRIPPING LUBRICANT
PART #3634770
PART #3634770
FWIW-I only hand wash mine or just spray rinse the dust of at the car wash, when I do, I never hit the top, just the metal areas...I cant imagine their are people that take their vert thru a drive thru car wash...wow, crazy.
the other part is weatherstripping. i'll start at the front. my sleeve was getting the dripped on. i looked at the it when the top was down and all looked normal. then looked at the other side and noticed the difference. at the top there is a bowl shaped end piece that mates with the top when it comes down. if you cup your hand that is what it looks like. well, there was a piece of the rubber that had been folded over somehow and it made a little space for water to drain through. the fix for me right now is to hold it flat till i lock the top down. now for the back.
look at the weatherstipping at the top of the window at the top back corner. mine hangs a bit lower than it should. as the top comes down to close, it hits a guide and it should line up. mine needs some adjusting, maybe this weekend. right now i push out on the top as it comes down and it lines up perfect. that's it for the back.
i can't say i've noticed any water in my trunk though.
that takes care of the top parts. the window needs to be adjusted as well. you can tilt, rotate, raise, and lower the thing. it takes some trial and error though not to mention patienece. the door is made of fiberglass i think which means be very carefull not to crak it.
i did my best to describe things and i'll try to post some pics later. hopes this helps.
now, i wish i could find a quick fix for that g**dam hump in the passenger side.
