Convertible Vehicles Enthusiasts | Information | Maintenance
need help
Old Apr 28, 2008 | 09:29 AM
35ss's Avatar
Default need help
my 02 ss vert will cycle in the down position but when i go to raise the top it doesn't do a thing ive checked the pump for oil and it is a little bit below the second line i don;t know what else to check for.
Old Apr 28, 2008 | 10:41 AM
JohnnyBs98WS6Rag's Avatar
The top switch has been known to go bad in one direction. If you get NO noise from the motor in one direction, check for power at the motor connector when the switch is activiated. 12 power should show up at the motor connector when the switch is activiated, and reverse polarity in the opposite direction. If this checks out, they you might have a motor or hydraulic problem.
Old Apr 28, 2008 | 11:10 AM
35ss's Avatar
alright il give it a try
Old Apr 28, 2008 | 11:28 AM
00cls1camaross's Avatar
try pushing it up with your hand and maybe it will catch. I have to do that sometimes.
Old Apr 28, 2008 | 01:02 PM
35ss's Avatar
i did that and nothing happened
