Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
yaw sensor
Old Oct 16, 2008 | 09:31 PM
jamesnorthprov's Avatar
Default yaw sensor
have been setting dtc 1282 yaw rate bias circut fault. need to know it sensor needs some alignment as there is some typ of set screw attached to the mounting point. had nav system installed , it was fine before install, thinking installer could had hit sensor as it is under ac controls. thanks for any help, jim.
