Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
car progress
Old Dec 31, 2008 | 12:36 PM
86MonteSS's Avatar
Default car progress
For those of you that don't know, i bought a nice package from speed inc. its well on its way to being done. :-) here are some pix for those of you that have been curious.
this is after cleaning the engine bay up a little bit.
accessories and what not pulled off
heads and intake off
inside the cylinder. they are smooth as ****!
underside of the car
shifter and what-not out
new LS2 flywheel
clutch in
old clutch/flywheel/pressure plate (can you tell i drive it hard?)
LS7 clutch on the left. Stock on the right.
rear coming down
rear on the ground
rear end on the ground. DTE Brace installed
new heads and headers in place (not bolted in)
i'm just waiting on a couple miscellaneous things and the car will be done. :-) can't wait to get the PCM back from Speed Inc (mail order tune. it is their SI5 cam. figured they'd know how to tune it best) and get this thing started!
new pix
new video
Www.YouTube.com/watch?v=x3-n7w07CZc
Www.YouTube.com/watch?v=LIYzMJYP8_I
Old Dec 31, 2008 | 02:12 PM
scramblerman's Avatar
looks like it is coming along really good.
How was it to drop the rear and the torque tube from the vette? Pretty straight forward?
Looking to do a clutch, heads, and hardened output shafts eventually on my vette.
Old Dec 31, 2008 | 03:18 PM
86MonteSS's Avatar
everything went smoothly except getting the bellhousing off. the clutch wouldn't go in through that opening.
Old Dec 31, 2008 | 03:54 PM
y2kc5's Avatar
Lol man you should have asked!!! you dont have to remove the bellhousing all you have to do is tap in the dowel pins a bit and it slides right in i just did mine last month..
Old Dec 31, 2008 | 08:50 PM
CHIWS6's Avatar
it looks like fun, i will more than likely be tackling this in the future. so u really don't have to take the bell housing at all?
Old Dec 31, 2008 | 09:13 PM
y2kc5's Avatar
nope let me know if ya need some help
Old Dec 31, 2008 | 09:23 PM
CHIWS6's Avatar
where in chicago r u located y2kc5? im located in the south side
Old Dec 31, 2008 | 09:27 PM
y2kc5's Avatar
me 2 im in richton park south of rt 30
Old Dec 31, 2008 | 09:35 PM
CHIWS6's Avatar
i'm not that far south, i'm 10 mins north of midway. ur closer to scramblerman. how long did it take u to do the clutch? was it ur 1st time? any special tools needed to take it off?
Old Dec 31, 2008 | 09:42 PM
y2kc5's Avatar
It wasnt that bad just make sure you have it up high enough and have a good trans jack strong enough for the trans /diff and torque tube to come out... It was my first on a c5 so it looked pretty scary could have done it in an afternoon but i ended up doing heads /cam install along with it..
Old Jan 1, 2009 | 10:43 AM
socmguy's Avatar
Restricted User
The dowel pins on the LS2 flywheel? I guess that makes sense. It was why the disc and plate wouldn't go up. I'll keep that in mind. Those bellhousing bolts made my top 5 list of PITFA bolts to get to. Right along with the Trans dipstick tube bolt on the back of pass. head (F-body).
Old Jan 5, 2009 | 08:53 PM
socmguy's Avatar
Restricted User
Did you pull the pins out or hammer them in?
Old Feb 1, 2009 | 02:26 PM
86MonteSS's Avatar
first start up!
http://www.youtube.com/watch?v=x3-n7w07CZc
Old Feb 2, 2009 | 07:01 AM
86MonteSS's Avatar
Wow, I was expecting at least one response from tech! Haha. I got 2 pages on a mustang board!
Old Feb 2, 2009 | 05:16 PM
86MonteSS's Avatar
more teaser video
http://www.youtube.com/watch?v=LIYzMJYP8_I
Old Feb 2, 2009 | 05:24 PM
86MonteSS's Avatar
new pix and video added to first post
Old Feb 3, 2009 | 10:33 AM
obi-1's Avatar
Nice. My setup is almost the same, except no Fast intake and slightly smaller cam. A lot better than stock.
Did you drive around without mufflers? Sounds great but makes your ears ring after a while.
Old Feb 4, 2009 | 03:29 PM
tin's Avatar
tin
Default heads & cam
About how long did it take to do the heads and cam ,I am thinking of doing the swap myself., good job on yours ,sound great ,
Did you dyno yet?
Old Feb 26, 2009 | 09:13 PM
86MonteSS's Avatar
got a couple vids for ya
idle and launch
http://www.youtube.com/watch?v=wcEt6o3RQbc
traction? at 50? are you kidding?
http://www.youtube.com/watch?v=iAod5GqDTno
Old Mar 8, 2009 | 07:01 PM
86MonteSS's Avatar
http://www.youtube.com/watch?v=8eKFUGqsbUA
http://www.youtube.com/watch?v=OmmCxdOuYJM
