Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
06 LS2 DFX Clutch Question.
Old Feb 11, 2009 | 05:01 PM
Bullitt347's Avatar
Default 06 LS2 DFX Clutch Question.
I am installing a DFX Clutch and Aluminum flywheel, all from Centerforce, and was wondering if anyone had an issue with getting the right throwout bearing for this combo. I have already called Centerforce and was told that they do not make a T/O bearing for this application, and suggested possibly a new OE T/O bearing might work. Any Thoughts.........the original T/O bearing seems almost a bit to small in diameter for the new pressure plate. Thanks in advance for any help.
Old Feb 16, 2009 | 11:58 AM
C5_Pete's Avatar
It seems odd that CF wouldnt know what TO bearing would work with their clutch. That just isnt right.
"Hi, this is Centerforce. Sure, we'll sell you a clutch, but we have no idea what slave/TO bearing to use with it. Sorry"
I would expect the stock TO bearing assembly should work though.
I've heard good things about the DFX, so I hope you find an answer.
