Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
? about wheels.
Old Feb 16, 2009 | 11:27 PM
CobraB8_ZO6's Avatar
Default ? about wheels.
I need a set of M/Ts, and I have a set of Trans Am 16" wheels. I was wondering if they would fit on the back of my C5Z. Thanks for all the help.
Old Feb 16, 2009 | 11:56 PM
Cole Train's Avatar
probably will fit but i'd just get s set of wagon wheels off Corvetteforum. They will damn near give them away
Old Feb 17, 2009 | 12:09 PM
02SCVette's Avatar
I've gone with the 16" firebird rims and you have to do some work to make them fit. Take a hammer and bang down the upper ball joint a bit. Then you have to shave some of the aluminum off of the upper control arm to the sides of the ball joint. It's been done many times and I've never heard of an issue. It's a slow process since you'll have to fit them on and take a little more off as you go. Another option might be to remove some of the inside of the rim for the clearance...
As mentioned, the 17" is not an issue with clearance but you loose some of the sidewall flex.
Old Feb 17, 2009 | 06:53 PM
The side wall issue is why I wanted to go 16s but I dont want to do any cutting or hammering on my car, so I guess Ill have to do 17s. Thanks man.
Old Feb 19, 2009 | 04:36 PM
02SCVette's Avatar
I can certainly understand that. It's not much modification though. Here's a pic of the passenger side clearanced and one of the drivers side stock for comparison. It's really not much of a difference but it takes a while if you don't want to take too much off.
Attached Thumbnails ? about wheels.-clearanced-pic.jpg   ? about wheels.-untouched.jpg
