AC compressor, bad job?
Not very fun. There are 2 other bolts from underneath you'll have to remove while you are unbolting the engine mounts. Just use some short 2x4 wood blocks to push the bar against. That'll help you push the engine to the side. Some muscles are certainly needed for it and it's certainly not a 1 person job.Maybe somebody has a trick that makes life easier but we couldn't figure out an easier way.
Good luck!
Can't blame you there! I snapped a pic last night since I was looking to see if removing the WP would have worked. It makes sense that it would but there still isn't much room to move stuff out of the way in there...
