Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Meziere pump install how-to inside
Old Oct 13, 2003 | 07:13 PM
jmX's Avatar
jmX
Default Meziere pump install how-to inside
Once again it took me a while to finish this thing off, but I wanted to make sure it was pretty complete before I posted it.
Click here: http://www.ls1howto.com/index.php?article=27
That is everything you need to know about installing your own Meziere. If those who have installed one themselves want to give it a glance, that'd be good too. I may have left out some small stuff here or there.
There are diagrams to wire it up simple, wire it up with a relay, or wire it up with a relay and a manual override switch. There's about 50 different ways to wire the thing up, so if you dont like one of those 3, then feel free to wire it up on your own.
For the F-body folks, that version will be ready very soon too. This version is for C5's.
Old Oct 13, 2003 | 11:31 PM
U LUZ's Avatar
Default Re: Meziere pump install how-to inside
I JUST DID THIS MOD MYSELF THAT IS A VERY GOOD WRITE UP I WISH YOU WOULD HAVE DONE IT LAST WEEK ....I HAD TO GRIND ON A BOLT HEAD A LITTLE BIT {THE BOTTOM BOLT ON THE ALT. BRACKET}BUT ALL IN ALL IT TOOK LONGER TO FIND A HOT WIRE AND SOLDER IT IN THAN IT DID TO INSTALL THE PUMP...
