Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
HELP no start
Old Mar 4, 2009 | 09:34 PM
AutobahnCCZ06's Avatar
Default HELP no start
So i took my 2003 Z06 for a little drive around the block today just to get things moving since i was planning on changing all of the fluids tonight but first i was going to change the oil in my buddie marks TBSS, so i parked the Z06 in the drive way with the wheels turned to the left a little bit, but once i was done changing the oil in my buddies TBSS i went to start my car and put it on the lift, but when i tried to start it the key kinda had a hard time going into the ignition, and then once i got it in the ignition it wouldn't turn until the 4 try, but now the car won't start and the steering wheel is locked into position and won't move no matter what i do. so now my car is stuck in the drive way at a weird angle which makes it difficult to get around ( i will manage) but now the car won't start and the is now way to move it, wtf and i was planning on insuring it this friday. the only other time this happened was when i reflashed my car with hp tuners and i figured that out and i tried the same thing tonight and no luck, HELP ME any advise will help. thanks.
Old Mar 5, 2009 | 08:51 AM
fastorgbird's Avatar
Do you have any fire in your battery? If not you should give it a good old jump. And if it starts then the way to unlock your steering wheel is to let the car run for awhile. This is because you needed the battery to build up. Turn the car off and bump you steering wheel side to side until it let go.
