Crank bolt walked out Z06 - getting confusing information
lol
I did order the Thunder Racing TR224 kit...
What is better about the ls2 chain? Stouter?
Also since they'll have the engine apart they will likely bump the oil pressure sender and it will go bad after too long and you'll be wondering why it says you have maxed out oil pressure. So you should change that out too
Also might as well build it to a 408
lol kidding on that part but the rest, i'm serious
It was an experience. The most complex engine pull I have done. All I had to go off was an internet magazine article.
The new crank, crank bearings, rod bearings, balancer, chain, oil pump, and labor ended up being about $1200 at the shop I always use. I had the shop do the short block, and I did the top-end, which is a straight-forward pushrod v8 deal.
I don't know what I spent in gaskets, but it wasn't a whole lot.
I did have to replace both the water pump and the power steering pump. If your crank bolt spins out...check your accessories. On my water pump the pulley was out of round and went slightly in and out. On the power steering pump the shaft was warped. The other accessories were fine.
I left all the injectors and wiring on the manifold, and simply flipped it over backwards and zip-tied it to the torque tube. I didn't take any pictures and the harness ended up being real straight-forward due to this trick, because everything stayed relative to the manifold.
Every collector stud/bolt broke during dissassembly. There are 6 of them, but GM sells them in packs of 5...go figure.
I put the TR224 cam in. I haven't had the car above 3,500, but drive-ability is like stock. Seems like a great upgrade so far. I will be getting the computer tuned soon.
I also put the ls7 clutch in, which seems great.
It really wouldn't have been that bad of a project, except that I had a hernia surgery while the engine was in the machine shop so I had to put it back together on vicadin with ice bags in my pants
hahah.... sighIf anyone has any questions about doing this job, feel free to PM me and I'll offer whatever insight I can.
More common on the LS1 / LS6's. Haven't heard too many issues with the LS2/LS3's.
