Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Went to the track last saturday!
Old Mar 28, 2009 | 11:44 PM
ricky02c5's Avatar
Default Went to the track last saturday!
I took my 2002 m6 to gateway on saturday, here's how we did.
1st run
r/t .290
60' 2.216
330 5.665
1/8 8.503
mph 86.96
1000 10.909
1/4 12.992
mph 112.38
2nd run
r/t 2.80
60' 1.991
330 5.445
1/8 8.258
mph 87.76
1000 10.647
1/4 12.649
mph 113.03
3rd run
r/t .427
60' 1.969
330 5.420
1/8 8.243
mph 87.48
1000 10.640
1/4 12.649
mph 112.642
The track prep was bad. I was having slight wheel spin most of the way through 1st, even on bfg drag radials. overall i was happy with the times, and it looks like with a solid 60' the car will be close to 11's. The only mods are a K&N cone filter, cat delete, x-pipe, no mufflers!
Old Mar 29, 2009 | 08:50 AM
Superman09's Avatar
LS1Tech Sponsor
Very nice, I went yesterday with my '99 coupe. I was trapping right about the same as you but no where near the 60'. I was on 19" street tires with a best of 2.1. How are you launching the car with the DRs? Thanks!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Mar 29, 2009 | 04:21 PM
ricky02c5's Avatar
I was letting the clutch out fast from 3-4k rpm, almost dumping the clutch. I tried slipping it some on the first pass but that got me the slower 60'. So on the next two passes i gave it more rpm and faster clutch release. If the track was better and with a bigger burnout the 60' would have been closer to 1.6-1.7.
Old Mar 30, 2009 | 08:34 AM
pontiac's Avatar
what all you have done?
Old Mar 30, 2009 | 09:55 AM
87turbo2's Avatar
+1 !
other than the exhaust work what gears do you have, what tires, etc...
Old Mar 30, 2009 | 01:10 PM
Fastbird93's Avatar
Those are VERY stout numbers for what little mods you have listed.
Old Apr 3, 2009 | 12:30 AM
ricky02c5's Avatar
I have very little done to the car. Only mods are a K&N cone filter that replaced the stock airbox, x-pipe with the cats deleted, and no mufflers! stock 3.42 gears. I had my buddies wheels on the back with 315/40/17 BFG drag radials. The drag radials didn't even help out nearly as much as they could have with the best 60' being a 1.969. It was opening day at the track and the prep was bad. I think it can break into the 11's with a great 60'. That would be bad *** with only having about $200 in the car!
