Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
View Poll Results: Which peforms best in terms of track performance
Halltech Venom
0
0%
Callaway Honker
7
50.00%
Vararam
5
35.71%
Vortex Rammer
2
14.29%
Blackwing
0
0%
Multiple Choice Poll. Voters: 14. You may not vote on this poll
Vortexx Rammer or Callaway Honker???
Old May 8, 2009 | 05:48 PM
JeaneGrae's Avatar
Default Vortexx Rammer or Callaway Honker???
these products look like the function in the same manner, do they yield similar results? Are they both better than the Vararam and Halltech Venom?
Old May 8, 2009 | 08:24 PM
David Gordon's Avatar
The Calloway looks first class and makes decent power. The Vararam provides good results at the track on C-6's.
Old May 8, 2009 | 09:36 PM
c6r's Avatar
c6r
Generally speaking, they both make about 11hp in most test. I choose the honker setup for my vette, I do notice that the filter stays cleaner longer than just an open filter element type. Hell after a day or two you want even remember it's on your car.
Old May 9, 2009 | 12:09 PM
Mike02Z's Avatar
I think the Vararam makes slightly more power than the Callaway. The Vararam is a bottom feeder. It sits directly in the airflow. The Callaway is a back feeder. It is still in outside air but is not scooping air as directly as the Vararam.
All that being said I'd NEVER use a Vararam. I went with a Callaway. I have 2 reasons why the Vararam is not for me.
The build quality of the Vararam has been questioned in thread after thread on Corvette Forums all over the net. The seal between the upper and lower box does not stay put and this can allow unfiltered air to get into the engine. The second reason is that more people seem to hydrolock their engine with the Vararam than with any other CAI. Because the Vararam sits so low it's easier to suck water up then with the Callaway. The Callaway sits up much higher than the Vararam.
I have read one person who said they hydrolocked their engine with the Callaway compared to multiple people with the Vararam. I don't drive my Corvette in the rain very often but this was a bit of a concern.
My main reason is I just don't want to have to check the Vararam weekly to assure it is not allowing unfiltered air into my engine.
Old May 9, 2009 | 01:03 PM
c6r's Avatar
c6r
Actually the way it was explained to me is that the honker setup used pressurized air feeding into the intake from the high pressure area were the air feeds into the lower radiator opening instead of just sitting directly were the air first enters( low pressure area ) and the callaway z06 racing team just won the international racing championship against cars like ferrari, ford gt, aston martin, porsche etc. using the same type of setup, racing is the best proving ground.
Old May 9, 2009 | 10:31 PM
siffert's Avatar
What exact championship was this?
Old May 10, 2009 | 08:00 AM
c6r's Avatar
c6r
fia gt racing log on to( corvettemotorsport.com )for the details. I LOVE ROAD RACING!!!!!!!!!!!!!!!
Old May 10, 2009 | 09:17 AM
siffert's Avatar
Thanks for the info! I have the Xcelerator CAI, similar to the Honker.
Old May 10, 2009 | 09:22 AM
c6r's Avatar
c6r
I have the same one, bought it at MTI YEARS AGO
Old May 10, 2009 | 05:25 PM
siffert's Avatar
Yea, me too...though they no longer are in the Xcelerator business.
Old May 10, 2009 | 11:00 PM
JeaneGrae's Avatar
Default pics....
does anyone have any pics of the xclerator intake?
Old May 11, 2009 | 04:45 AM
c6r's Avatar
c6r
Log on to (corvettes of houston).com should have pics there.
Old May 11, 2009 | 06:26 AM
siffert's Avatar
Here you go:
Old May 11, 2009 | 06:52 AM
JeaneGrae's Avatar
Default ......
this looks very similar to the Honker and Rammer sett up. What puts the Honker over the top, abpve the rest? Does it seal better, pressurize better??? Would the Xcelerator or Rammer yield better gains? Does anyone still sell the xcelerator kit for c5's?
Old May 11, 2009 | 06:56 AM
siffert's Avatar
They are pretty much all the same performance. The xcelerator was a low priced clone of the Honker selling for around $275.00 There never was any xcelerator kit for the C5, only C6 LS2 and LS3. One advantage it
has is that you could buy an optional pre-cut/pre-riveted shroud so you didnt have to mess doing it yourself.
Old May 11, 2009 | 11:31 PM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
Vararam - poor build quality, PITA install.
The other 3 are the same. Vortex is the lowest in cost. Go with that one IMO.
I used it on one of the C5s I had in the past. I paid ~ $250 for it AND a pre-cut radiator shroud for quick install and saving the stock one. Took literally 15-20 minutes to install.
Old May 12, 2009 | 08:49 PM
scramblerman's Avatar
Got the vararam in my car and love it!
Not one problem with the build quailty, got the newer VR2 one. The install was a bit of a pain but was worth it. One for the vararam!
Old May 13, 2009 | 06:05 PM
JeaneGrae's Avatar
What makes the varam so hard to install? is it similar to the super sucker ram air for fbodies?
Old May 13, 2009 | 07:03 PM
hopefully this will clear it all up. It helps to have another person when doing this. I have had no cracks or any fitment issues with mine. Installing took a while to do but in the end I think it is the best system out there.
http://www.zbramotors.com/vararam/VaraRam.html
