Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
zex tps wot switch problem
Old May 17, 2009 | 08:55 AM
smokin91rs's Avatar
Default zex tps wot switch problem
ok i used this setup on my trans am. im using a zex t.p.s. activated wot switch to activated my nitrous. on my 99 frc im using the pink wire and my noids will work fine with the key on engine off when the car is running as soon as i arm the system the noids fire. i tried to use the bluse tps wire like some others and it goes in to reduced power even with the arming switch off? y is this? im runnign a ls2 tb as well is the zex switch just not compatable
