Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
vararam vs halltech
Old May 22, 2009 | 08:21 AM
camaroracer91's Avatar
Default vararam vs halltech
which is a better intake for an 01 z06
Old May 22, 2009 | 08:26 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I was happy with the Vararam went I had it on my car. I am sure most people are going to suggest the Vararam.
Old May 22, 2009 | 08:30 AM
did you have any problems with running lean after the instal
Old May 22, 2009 | 10:24 AM
scramblerman's Avatar
I love my vararam.
In about 6 months after doing mine it set a lean code 3 times. More so when it was really hot out.
Old May 22, 2009 | 02:09 PM
--Z06--'s Avatar
Same here, I am getting lean codes all the time now.
P0171. Two banks are running lean. It is intermittent, but annoying and worrisome. Since I have not noticed THAT big of a performance increase, I may pull mine out and sell it for some thing else for the car.
Old May 22, 2009 | 02:30 PM
thats what im afraid of id rather get halltech if im not going to run lean all the time
Old May 22, 2009 | 03:49 PM
Chris81's Avatar
I love the Vararam on mine.. if you get the car tuned by someone that knows what they are doing you won't have any problems with codes IMO. I do all my tuning and haven't had a code EVER in the year and a half i've had everything on the car. My car traps pretty well in bad air with the help of the Vararam CAI (that mph corrected for my altitdue is 120.69 FYI).
The problem has to do with the MAF seeing the sometimes sudden rush of air due to the high flow characteristics of the Vararam. My car will sometimes surge a tad if i'm going into a strong headwind with a light load on the motor because of this, but no codes. The reason other CAI's don't do this is because they don't work as well.
Old May 23, 2009 | 05:51 PM
CySevans's Avatar
I have the Vararam on my Z06 with a tune, so no lean problems here. Loving it. Just don't drive through standing water. Ever.
Old May 23, 2009 | 07:19 PM
like how much water cause im going down to florida where it does rain alot
Old May 24, 2009 | 11:34 AM
I have known people that have driven their cars in downpours with the vararam and had no problems. Then I have heard a story or two about people going through water and screwing up the engine. If you look at the setup, that water level would have to be at least halfway up the front end of the car and the car going pretty quick for that to happen. The vette is not a damn 4x4 truck. If you see alot of standing water, stop and think. It is COMMON SENSE, use it.
Old May 24, 2009 | 01:08 PM
CySevans's Avatar
As little as four to six inches can cause problems depending on how fast you are moving. It will create a wake, and the Vararam is like a vacuum cleaner in the nose. If you see standing water, just go around it or take a different route.
But even the stock one can suck water if you're not careful. There are warnings in the owner's manual.
