Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
LS6 Piston Strength?
Old Jul 8, 2009 | 09:09 PM
BADZ's Avatar
Moderator
The stock ls1/ls6 pistons are made from castings and were not designed for high hp's. The rod bolts are the weak link in these rotating assemblies and normally these give up causing the piston and rod to shatter/break in pieces. I been there before on several ls1/ls6 engines..I would change out the pistons and rod bolts if I were going to do a budget build.
Old Jul 8, 2009 | 10:14 PM
SCM_Crash's Avatar
I'm going to pull the console off and see what shifter is in it. It could be a Hurst or a B&M. I won't know until I pull it apart. What I do know is that the throw is really short. Seems like maybe about 1/2 inch from center to 3rd. When I first tried it out, I didn't know if I was in gear or stuck at the gate. LOL
I also know that the springs are really stiff. When shifting from 1st to 2nd a few times it sprung back to the center REALLY fast and I had to pull it back over to get it into second.
