Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Upgrade The Clutch???
Old Jul 27, 2009 | 03:58 AM
TransAmcoupe98's Avatar
Default Upgrade The Clutch???
I need some advice from you guys. The following mods in my sig are being put in as we speak. I was also thinking about replacing the clutch. I'd say with those mods it will be putting down around 450rwhp. Do you think I will be ok on the Ls6 clutch? I don't go to the track a ton and I use street tires when I do. What do you guys think???
Old Jul 27, 2009 | 11:40 AM
ZONick's Avatar
My car has been running the stock clutch, but after a while it has started to slip. it should hold the power for a while especially if you are nice to it, but it will need to be replaced eventually. I'm getting an oz700 in tomorrow.
Old Jul 29, 2009 | 10:15 AM
Chevy406's Avatar
If you are in Winchester, TN you can stop by and check out my '99 with a Textralia Z-grip clutch. It's a bit grabby for a daily driver (which mine is), but it holds great with sticky tires. Enough to snap the output shaft in my differential. I am thinking about swapping it out to an LS7 setup.
On a stock LS1 clutch my h/c/i/ex LS1 would slip pretty bad if I launched over 2,500 rpm with sticky tires.
