Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
402 stroker
Old Aug 3, 2009 | 02:35 PM
ls2's Avatar
ls2
Default 402 stroker
hello every body im thinking that i sell my stage three heads and buy a 402 short block and install stock heads and mti stealth 2 cam it will be NA and in few months ill buy afr or trick flow heads so what do youl recomend
Old Aug 3, 2009 | 05:42 PM
pittman's Avatar
A 402 with afr's will scream with the right cam !
Pitt
Old Aug 4, 2009 | 06:42 PM
pittman's Avatar
Got your PM.
For your info..I just bought a TS short block and upgraded the rings and ARP bolts. Bought some afr 225's and a Fast, then sent them all to Pete Incaudo for porting\polishing. He chose a street cam for my heavy azz truck, slapped it all together in my garage and BINGO...11.17 @ 117MPH, then backed it up with different tires on a different day with a 11.18 @ 119 mph.
The motor is so strong I don't even launch hard. Watch this video.
http://s160.photobucket.com/albums/t...b1117mpeg2.flv
This cam is bad news but is really mild. Perfect Street Sleeper !!
http://s160.photobucket.com/albums/t...urrent=402.flv
Pitt
Old Aug 4, 2009 | 06:44 PM
pittman's Avatar
Here is the idle. This cam is pretty dang mild but...bad news and the perfect Street Sleeper.
Pitt
Old Aug 5, 2009 | 01:33 PM
allngn_c5's Avatar
Might I suggest going thru Vengeance Racing for your new short block? I say this because buying a shortblock is not a cheap investment, and Vengeance gets all there shorts from ProLine. ProLine turns out top notch shorts. You get what you pay for brother. I wish I had went there first, I'd probably be making 565 rwhp 515 rwtq vs the numbers in my sig. Give RON a call. Number is in my sig too.
Old Aug 10, 2009 | 12:20 PM
BADZOH6's Avatar
Go with the Trick Flows. I have never seen an AFR head make more power than a TFS head. Give Vengeance a call, they will shoot you straight!!!
