Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Drag Radials on stock c5 z06
Old Aug 9, 2009 | 10:48 AM
fastenough's Avatar
Default Drag Radials on stock c5 z06
Should I worry about breaking anything if just using these on the street?
I was considering using the M/T 305/35/18 or the BFG 295/35/18. I am leaning more towards the M/T b/c my TA has them and they work very well.
Thanks!
Old Aug 9, 2009 | 12:22 PM
LT1_Fireman's Avatar
No, you should not have anything to worry about and I would get the m/t.
Old Aug 9, 2009 | 12:49 PM
fastenough's Avatar
alright. I have an 01 z06 with just an intake. First and second gear seem to be useless. I've tried racing a couple cars including a GT500 which just resulted in me being sideways through 1st and 2nd even from a slow roll.
Old Aug 9, 2009 | 04:22 PM
venom ws7's Avatar
Get the MT You'll love them.
Old Aug 9, 2009 | 10:02 PM
sultan(ZR-1)KSA's Avatar
I want a set to dude
Old Aug 10, 2009 | 02:49 AM
fastenough's Avatar
I've heard of some breaking the IRS with these...any truth to this?
Old Aug 12, 2009 | 03:39 PM
fastenough's Avatar
up up up
Old Aug 13, 2009 | 03:51 AM
CS Vette's Avatar
Anything mechanical has the possibility of breaking at any time. That is just the nature of the beast. With that said, yes it is possible for even a stock motor to make enough power to break drivetrain components with a decent set of sticky tires.
Personally, I had Nitto DR's on the back of mine for a couple years and loved them. Didn't break anything either.
Old Aug 13, 2009 | 09:42 AM
slip the clutch and make sure you dont have wheel hop and you will be ok
Old Aug 13, 2009 | 02:56 PM
wetVdreams's Avatar
for street use only I would ****** a pair of nitto 555r's instead of the ones listed... you get a little more life out of them (especially the MT's) and with my H/C Z06 it dead hooks on the 555r's in 305/35/18's
Old Aug 14, 2009 | 01:15 AM
UVETTYA's Avatar
If you just use them on the street you probably will be ok. On a well prepped track you will eventually break something if you launch hard without slipping the clutch.
