Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Thinking about a Z06
Old Aug 10, 2009 | 10:09 PM
JayJaySS's Avatar
Default Thinking about a Z06
Don't know if I'm in the wrong forum, but I'm looking for an opinion. I have a 2002 Camaro SS, 6M 68000 miles. Long story short, my bike was recently stolen but the good thing is it opened up some more room for a nicer car. Dealer says they will give me $10,500 for my car as a trade in on a torch red 2001 Z06 with 41,000 miles. Car is listed at $20,995. Just wondering if it is a reasonable deal, anything I should look for/at on it,any notorious problems or noises C5 Z06s have. Any input would be greatly appreciated!
Old Aug 11, 2009 | 12:16 AM
Paul418's Avatar
I think you could get an 02 with less miles for $22k. 2001 had 385 hp and there were reported oil consumption issues with some. You should check vehicle history and see if anything was done concerning oil consumption. The 2002-2004 models had 405 hp AND heads up display which is a great feature.
Get under the car and look at the tires inside, the camber on the Z06 is setup that the insides wear first. Tires might look fine on the outer edge but may be bald on the inside. Also check the tire date. I wouldn't buy it if the tires were over 5 years old. Check the doors lock/unlock using the FOB AND the door control. Also check windows up and down. The modules in the doors are known for going out. Sometimes you can solder a new $5 relay and you're good to go. Turn key, hold down options button and press FUEL button 4 times. Computer should go into diagnostics mode you can press the various buttons to go up/down and see what codes the computer has set "C" - current, "H" - history. Google C5 Corvette DIC and read up on it. Write down the codes and check them or print a list of the codes off and take with you. See if anything looks unusual.
Good luck...
Old Aug 11, 2009 | 08:29 AM
JayJaySS's Avatar
thanks for the input, will do!
Old Aug 11, 2009 | 11:09 AM
hammert85's Avatar
I will sell you my 04 for $3,000 more with only 28k miles on it and a full GMPP warranty with $0 deductible. Let me know if your interested. My number is 585-739-8737. Thanks. Ryan.
