Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What will it do?
Old Aug 29, 2009 | 06:37 PM
SLOC5LS6's Avatar
Default What will it do?
'05 C6 non Z51 w/G6X3 cam, LS6 ported heads, Lingenfelter ported LS2 Intake, ported TB, Vararam CAI, LG PRO LTs and Xpipe, B&B catback, tune. The car made 460rwhp 408rwtq and has ran 11.7 @ 125.7mph on the stock clutch. Adding a LS7 clutch/flywheel, FAST 92 and 4.10s, what do you think it should run??
Old Aug 30, 2009 | 06:22 AM
c6r's Avatar
c6r
What was your 60 ft. & what type of tires were you runnning when you ran the 11.7 at 125mph, did you beef up the rear at all.
Old Aug 30, 2009 | 09:06 AM
pittman's Avatar
All being equal....tires, tire psi, weather & track prep...I would guess you would see 2-3 tenths. The only problem is learning how to launch again with 410's because of wheel spin. It took me a couple trips to the track to get mine to launch 1.4's again after going with 390's and already having the MN12 tranny.
Pitt
Old Aug 30, 2009 | 09:32 AM
SLOC5LS6's Avatar
11.7 with stock 19s - michelin tires street tires, 60ft was a 1.9. stock rear. along with the addition of 4.10s there will be upgraded halfshafts.
Old Aug 30, 2009 | 09:33 AM
SLOC5LS6's Avatar
Pitt
how much more mph do you think it'll pick up??
Old Aug 30, 2009 | 09:59 AM
usenterprise's Avatar
car will run high 10's with m/t dr. mph will be the same because your getting down the track quicker. my guess is 10.9 to 11.2 at 125.00. with a good 60ft. 1.6- 1.65. looking at old time slips. without dr's it will be more difficult to get out of the hole with 4.10s. so don't be disappointed if you get slower.
