Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
02 Z06 new engine wont start
Old Sep 22, 2009 | 04:35 PM
69ss's Avatar
Default 02 Z06 new engine wont start
i got the new cam/head 6.0 in and the car will start for 2-3 sec. and dies like the key shuts off. checked wire conections over and over. secerity light is not on. will a stock tune let the car idle? any help would be good THANKS
Old Sep 22, 2009 | 08:04 PM
V-seriesTech's Avatar
Put a battery jump box on the car,.... grab the keys,... turn the ignition on, engine off. Let the car sit with key on for TEN MINUTES or until security light goes out,... turn key off for roughly 5 seconds,.... turn key ON engine off, for ten minutes, or until security light goes out. Turn off key,..again, 5 seconds,... turn key on, engine off, one more time for ten or soo minutes... key off,.. wait 5 seconds,.. start the car.
The security light looks like a LOCK,... and your having a passlock theft problem. The vehicle is not sending a message to your fuel pump, allowing it to comeon and stay on.
Should solve your problem.
Old Sep 22, 2009 | 08:24 PM
69ss's Avatar
thanks gonna try that in the morning. car has been gettin the best of me.
Old Sep 28, 2009 | 01:57 AM
69ss's Avatar
i am not far from spreartech so i took computer over to john he took the vatts off. car still would not start. problem was a map sensor. put a new one car strarted but no oil pres. i took the front of the engine apart and no plug on the bottom right side. engine came from machine shop as a complete short block.
Old Sep 29, 2009 | 05:47 PM
mjcotroneo's Avatar
if your getting no oil pressure and the engine is running and not knocking or ticking. replaced your oil pressure sensor they are common for breaking because they are so brittle. it sits behind your intake manifold. they are like $10-15.
