Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Low oil level indicator came on...
Old Oct 21, 2009 | 11:05 AM
50_Dave's Avatar
Default Low oil level indicator came on...
Guys, i recently got the low oil level indicator. This is the first time its happened, and it just happened recently (a few days maybe) after i changed my oil. I checked my dip stick, it says im full, and my oil pressure is good. It came on as soon as I turned on the car. I reset it, and it came on once more as i was driving home.
This is on a sts twin turbo z06 with a 402 and a lingenfelter high volume oil pump.
Any ideas?
Old Oct 22, 2009 | 12:53 PM
SStheBest's Avatar
bad sensor??..check the DIC and find out exactly what your car is tellin you....
Old Oct 22, 2009 | 03:07 PM
1BADBURB's Avatar
yes, check the codes and report back...
im guessing its a bad sending unit on the sensor. common issue on these cars.
also, fyi, if low oil level comes on, you have 4qts left in the pan...
Aj
Old Oct 22, 2009 | 09:25 PM
green97ss's Avatar
mine came on because i was parked on a incline
