Questions on c5z06
These are cars are also known for electrical issues, make sure the climate controls work, and that the DIC does not display any warnings, also check the headlights operate normally. I bought the formula with the rear diff stripped to **** (didnt know at the time) So is the rear end weak like it is on the F-Bodies?
Formula also came with H rated POS kumo tires... and I know eagle F1s come standard, but what tires are generally decent for daily driving a vette?
TA threw a piston straight down through the engine within a month of buying it... So are there any tell-tail signs of an upcoming shitstorm of engine repairs that I should know about?
Camaro vert top leaked like ****, formula T-Tops had small leaks as well... So are there any issues with the FRC seals? or window motor issues?
And of course... what is the speaker size for a c5z? ... or any special systems to get around like the shitty monsoon system in f-bodies?
I read that there were special jacking/lifting requirements... and since I plan on attempting repairs/mods in my new garage (whenever we get the house), what is the easiest way to get at under-car components. I assume a simple jack isn't the answer.
I would really like to come into this as knowledgeable as possible.
If it went in for the recall, I'd recommend not getting that car or get a CLB right away ($50 - 20 min easy install).
If it didn't go in for the recall, I'd give it a green light to start looking for other issues on the car to see if you want it. The CLB should still be installed when you get it. It's a good insurance to make sure you don't get stranded anywhere.
Look at the grounds behind the headlights and front fender wells under the hood. See if they're corroded. If there's just a tiny bit of oxidation or corrosion, not a big deal, but if there's a lot, you're likely going to have lots of little gremlins in the electrical system. Go through the computer to see if there's any codes being thrown. Easiest way to do that is to put the car in the ON position (don't start the car) and while holding the OPTIONS button hit the FUEL button 4 times (5 to go to manual scroll mode). That will let you know what kind of codes it's throwing. Anything that says BCM or ECU is likely not good. You may see TCS or RDO which is fine... The TCS usually has to do with alignment or over inflation of the tires (although can sometimes be the steering wheel position sensor which is expensive to fix). RDO is just the radio. Sometimes during weird starts on the car, the radio will temporarily lose communication with the BCM and throw a code. No biggie as long as the radio is working.
Look at the exhaust to see if the pipes are lined up right. If not, there's probably been an accident that caused them to go crooked.
Open and close the headlights a few times and make sure they both go up and down fine. They usually don't make a lot of noise (WAY more quiet than the Trans Am lights) but may give a little squeak... That's no biggie. If one comes up WAY faster than the other, the slower one's motor is likely going to die soon. They should both be up within a half a second of each other.
Run the A/C. See if it blows cold. Doubtful a C5 needs a freon recharge but if it doesn't blow cold it could need a compressor (although also doubtful). Also, if a car has really low miles and the A/C is never run, the A/C seals can crack, so double check it's blowing cold.
Listen for rattles in the test drive. (Don't let them turn the radio on while you're driving.) If the car's rattling, then the panels have likely have been pulled off... It's hard to make them not rattle once they start. When some people do audio work, they use the same retainers instead of new ones and it causes the panels to rattle really easily.
Double check the memory on the seats... Sometimes the memory module goes bad way early and it doesn't remember the position on the seat. (but should still remember the radio and A/C settings)
All the T56 transmissions clunk around, but if you're getting a harsh clunk when you're letting off the clutch, you've got something loose in the drivetrain and that's REALLY expensive to fix on C5s and C6s. The diff is also stronger than the LS2 C6's, but can still easily break with wheel hop, so listen for the diff as well.
Aside from that, there's no real adjustments since the car handles better and is far easier to drive. Less blind spots. Easier to park...
You just can't go wrong.
