Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
reduced engine power?
Old Jan 10, 2010 | 01:51 AM
ricky02c5's Avatar
Default reduced engine power?
i've got a problem here. while on the highway in 4th gear at about 4k rpm i went wot and then immediately rpms dropped to about 1800 and the screen said reduced engine power. i had to putt it home with it not letting me above 1800rpm. Even in neutral it stayed around 1300 to 1500. I checked the code and it was p1514. TAC maf performance. My maf has been descreened and gutted thanks to my dumb *** friend talking me into it. It was then dyno tuned due to it having a crappy idle and inconsistent performance. The tune was done 3 months ago, it has been fine until now. Do i need a new maf? Any help appreciated.
Old Jan 11, 2010 | 07:57 AM
WADDISME's Avatar
That would be a good place to start. Mine thru the 1214 from a leak in the intake, but that doesn't sound like your issue. Good luck with finding the problem.
Old Jan 11, 2010 | 01:38 PM
03Sssnake's Avatar
Disconnect the negative lead from your battery, pull the maf and clean it with some MAF/electronics cleaner. The battery being disconnected for a little while should reset your PCM. You may very well need a new maf since yours was gutted, possible its throwing off the pcm. You should be able to pick up a used un-molested MAF cheap around here.
Old Jan 11, 2010 | 02:24 PM
ricky02c5's Avatar
thanks guys. i did think about disconnecting the battery to reset the computer. i'll try that and look at the maf.
Old Jan 11, 2010 | 03:09 PM
ricky02c5's Avatar
I looked at the maf and it was ok. Then i disconnected the battery, hooked it backup and now it runs fine! I'm thinking i need a stock maf though to prevent it from doing this again.
Old Jan 11, 2010 | 04:31 PM
00ls6camaro's Avatar
you might also chek all of your ground conections
Old Jan 14, 2010 | 08:00 PM
Rage Z06's Avatar
I had the same problem at one time. It was the plug connection to the mass air sensor.
