Jacking up car for oil change
Going to do a oil change my z06 tom, just wanted to know where the best jacking locations on the car are. I have a 3 1/2 ton floor jack that i just want to jack up the front and place to jack stands and then do my change..
Anything in the center towards the front?
Thanx
-Zee
You will also probably need to drive the front wheels up on some boards to get the front high enough to get the jack under the front frame. The back should be okay without this.
I see a post on here for someone selling the jacking pads, look below!
Anyway, drive the front on ramps, jack the rear up by the crossmember and support it with jackstands so the rear is up just a bit higher than the front, then jack the front up a little more by the crossmember (if needed) until you have clearance to get to the drain bolt and filter.
